Adjusting tie rods to straighten handlebars
MINTSRX00
ILLINOIS
2000 SRX. When I'm riding straight my handlebars are not 100% centered? They point a little bit to the right? How do I straighten this out? Do I adust the left tie rod or the right one? Anyone know? Thanks for the help!!
Adjust both. Straighten the handle bar. Adjust the left one out and then the right one in the same amount of turns as the left one out. Double check toe. You want 1/4" toe out.
There is also a tie rod/drag link between the steering stem and knuckle. If your toe/alingment is good this where I would start making adjustments ;)!
