Gerryjackman
I wondering if a 98 mountain max trailing arm will work fine on my 98 mountain srx it looks identical length seems to be same angle and everything just wondering what you guys think
Should bolt right on. Not sure it the head stamp is different though. Might want to check or swap them in pairs.
Gerryjackman
Perfect thank you
different caster angle on the spindle tube as well as a slight degree difference on the shock mounting bracket.
it will work if needed, but you can upset the front end a bit. off trail you wont notice.
