live 2 sled
Has anyone else experienced cracking along the creases of your exhaust manifold. My 02 Viper had to be welded and I know of two others with the same problem. If you are getting exhaust oil marks on your belly pan and under your exhaust valves, check your manifold for cracks in the creases.
KZOOVIPER
Yep, same problem here. Makes quite a mess under the hood. Yamaha said to bad.
