Hath91
I'm hoping someone can help out with an issue I just recently experienced. I took my SX-R 700 with 3300 miles for a ride to Canada, stopped for a bite to eat and drink, went outside, sled would not start(turned over, could smell fuel). Changed the plugs as they were loaded, sled started after about 5 seconds of cranking the engine. Crossed back over the border, stopped the sled and restarted no issues. About a mile from destination, pulled over on the trail to tap the kidney, before the engine could drop to idle speed, the headlight went out completely and a second later the engine died. Went to restart, no issues, sled started, however, again, before sled dropped to idle, head light went out and then the engine stopped! The sled restarted, arrived at destination, again, before the sled went to idle, the head light went out and the engine stopped. Had troubles restarting, finally got sled restarted after about 60 seconds, drove to snow bank, went inside to have a drink, came out about an hour or so later, could not start the sled. Tested spark...with key start, no spark until the key was released and that exact moment of releasing the key there was spark. No spark when pulling the sled over manually. Called a local dealer, they said it could be the ignition switch at first until I explained the whole problem, then they were like it could be one of two relays or I believe they said it could be the stater? Something on the engine...sorry can remember the component on the engine. Something I needed to hook a OHM meter to and check the readings.
Early in the season, the sled was backfiring every now and then, didn't think much of it until trouble shooting the issue on the snow bank that night and it was back firing quite frequently then.
I might note that while I was in the process of removing plastic to get to the ignition switch disconnect connector, I noticed that the wires where run very tight and briefly checked for worn wires and cracked wire insulation...not sure if it could be something as simple as a wire grounding itself out?!?!?!?!
Any thoughts on how to trouble shoot this issue methodically would be GREAT. I'm hoping someone has run into this issue before....here's to hoping
Thank you in advance!
