Hello, i have a 74 433 gpx and was wondering if solid motor mounts would be worth installing? The sled will be oval raced. Thanks Rich.
Yamaha Nutz
rich said:Hello, i have a 74 433 gpx and was wondering if solid motor mounts would be worth installing? The sled will be oval raced. Thanks Rich.
yes for the rear but do yourself a favor and use a exciter engine plate and front mounts put your solid mounts in the rear the exciter engine plate will allow you to line the motor up better than the stock 74 plate
