rubbersidedown
I have an 02 Viper with 9200 miles last night I started getting a fast flashing warning light and fast flashing engine light at speeds over 80 mph and then again when comming to a stop. I was able to duplicate it by playing with the slide in the throttle but engine still reves fine and is not down on power at all. I was looking at the tech area and there was no mention of a fast flashing light. All other opoeration seems normal. Low fuel stays lit up and low oil also lit up as normal. Thanks in advance Scott
			Cam/ Viper adict
Did you put low octane fuel in lately.. My 02 viper will flash engine and light when i have put that crappy fuel in.. Use octane booster and make sure you do not lean out the sled..
			rubbersidedown
I only use priemum only. It did have ethonal in the last two tanks but one was 91 octane and the other was 93
			Cam/ Viper adict
I am not sure as to witch code that would be flashing. Maybe someone will chime in that has had the same thing happen.. Is it possible that you have a wire rub through somewhere in the harness. Check connections at all the plugs and look for a loose wire..
			rubbersidedown
The only option I see in the tech data is the power valve system has the fast flashes.
			Cam/ Viper adict
have you checked your power valves for pull threws? Is your servo motor operating or do you have a broken cable?
