gasket needed
maxco
coloraDO
I noticed a leak on my trailer today. Looks like my chaincase gasket needs to be replaced. Problem is it is a Elkolhm dropped and rolled chaincase. Any help on where I might look?
dropped and rolled
drop and rolled, I guess I need to look at it further. If it was not extended, A stock gasket would work. how can I tell after the fact? I am using a 70 link chain does that mean that it is stock?
Usually you can see where they are welded up when extended. With a 70 chain I'd guess it's just a stock case so you can probably just get a stock gasket.
