03 Viper Is It Possible To Take An 03 Viper Jetted For 0-2000 Or So And Take It To The Black Hills And It Will Run Fine If You Drop The Needles But Leave The Jets Like A 147.0 All Across The Board And Y Would The Pto Side Be The Same Only Mod Is An Slp Can
CSKP0708 said:03 Viper Is It Possible To Take An 03 Viper Jetted For 0-2000 Or So And Take It To The Black Hills And It Will Run Fine If You Drop The Needles But Leave The Jets Like A 147.0 All Across The Board And Y Would The Pto Side Be The Same Only Mod Is An Slp Can
The jetting is all the same because it has staggered compression. The pto side should be 10-15 psi lower than the other two
