2000 venture 500XL melted ground wire
Yamahammer485
Espanola, Ontario, Canada
Hey all,
While looking over the sled, I notice the wiring over the gas tank attached to the metal hoop has melted, and only the ground wire. The plastic sheathing has entirely melted, exposing burned copper wires. This melted wire was grounded out on the pto side of the hoop, and the wire remains burned accross the hoop to the mag side. It eventually splices into ground from the handwarmers, and the grounds "upstream" from the burned wire to the grips are fine. Continuing, the burned wire continues into the larger wiring harness where it can eventually be traced back to the rectifier. Interestingly, from the rectifier, several grounds splice, includingthe one which is burned, and it is only ever this one single wire.
Next, upon closer inspection, the ground coming from the mag on the engine is also burned, that is, until it reaches a plug going under the motor, then its fine. So far, no rub through's under the motor.
With all that said, sled has 20 000kms, runs perfect except thumb warmer stopped working and the sled has a hard time idling when cold, regardless of idle speed. Also, tried many searches, came up with nothing.
Dont know why this happened, hopefuly only the rectifier?
Any ideas guys? Thanks in advance.
