PPS. inc
Gonna be 43 on sat. Viper with rear exchanger. Planning on staying off the trails as much as possible. Kinda worried the air temp is gonna be an issue. I don't know tho. If I keep her in snow will I be ok. If I foul plugs that's ok. There is about 30-45 inch off trail so that's what we are going after. Run power lines and boondock around private property. I bought it to ride it but don't wanna blow her up. Thanks guys. Rejet is not an option.
snoprokidf6
you'll be fine
as long as you're in snow
Ride it. You won't blow a sled up riding in warmer weather than it's jetted for. It will just run rich.
I've ran my Vipers across the water in 50F weather and left them jetted the way they were for the winter.
snotwister
VIP Gold
no problem. run it! .. turn carb heaters off if u want, but ive never noticed a difference leaving them on or off.
the 4th cooler sees alot of snow and sheds the heat well. not to mention its one heck of a piece of mind
if u really get into trouble u can pack your boards with snow but ive run into some warm days on beat up, snirt covered trails and never had a problem with it over heating
PPS. inc
Thanks guys. Mind is at ease now.
FJViper
I asked this same question a couple years ago and was told to remove my foam filter on the airbox just to take some of the richness out of the carb. Not really sure if it helped or not. Sled ran awesome and had no issues with overheating. I've got the rear cooler on mine too, infact..... I installed it before that trip.
PPS. inc
What y'all think, remove filter or what. Feeling much better about riding as temp now are forecasted at 39.... Thanks guys. Also just found out the new vipers will be at a local watering hole and fuel stop for the weekend. I got a helmet cam and plan on a demo with a review. I ride a viper now. Ridden the nytro for miles, a bunch of revs, a few artic cats but not the chassis the viper is on. I'm looking forward to it. My whole group rides yamaha and we all now jacked for this opportunity... Thanks guys.
roudyroy1
so will warm weather cause it to gurgle or bog? mine has been in the warm weather and i dont know if its related
bADa$$ SRX
most likely just running rich because the air is not as dense at warmer tempsroudyroy1 said:so will warm weather cause it to gurgle or bog? mine has been in the warm weather and i dont know if its related
roudyroy1
would running in 10- 15c weather with 90% humidity do that? the plugs did show some rich ness
you are running at 10 to 15C..you kidding.Time to park it.Your jetting will be way out of wack..
roudyroy1
yea i figured, i pulled the plugs and they went from tan to black. being in the wet conditions well water skipping probaly didnt help either lol. going down to -10 so time to get the isso alcahol out and go for another ride to clear the water out of it.
