Is the w arm from a viper the same as one from a srx?
			killerklown
no they are not.
			killerklown said:no they are not.
So I can't use a srx w arm in a viper suspension?
only difference should just be the bracket that is welded on them where the threaded end of the limiter strap adjuster goes thru. They are welding up an inch higher then others.Well at least the SXR ones are welded lower,I have mixed them up and used both on my SRX.Side by side they are identical otherwise..now a viper could be different..don't know.Check the parts fiche..but don't know why they wouldn't inter change..what do I know...lol
I just checked,the part #'s are the same for my 01 SXR600 and a 02 Viper..8CV-47331-01-00
the SRX one is 8DN-47331-00-00..basically the same...I have switched them around between the SRX and SRX because they are identical except for where they welded the brackets for the strap adjusters.You just use a longer strap is all.
Ok thanks!
