Finally got my SRX running good
IgoFast
Wisconsin Rapids WI
After having random electrical issue after issue with my 2000 srx I think I finally got every thing sorted out.
I found that a load relay switch was melted or shorted, replaced that then the sled would start and run for about 2 seconds. The load relay thing was shutting down the motor, Had another short some where
I bit the bullet and pulled the entire electrical harness out.
I found the wires rubbed threw under the motor, and about 2 inches before they go into the ignition box right above my left foot.
I un-taped the harness, fixed the wires and re-taped the harness and reinstalled.
This thing has never run so good, no more missing, shuddering or random lights.
Thanks for all the help guys
now keep it like that.I have been chasing things for years also.I finally have it running like a wild beast.I changed Stators and everything seemed to have changed for the better.It is a hand full on acceleration and that sweet sound is back..rpms dead nutz on to.Raising the ski's on launch is wicked now.But I try to keep skis down for better holeshot,but it seemed to pu more power now.Have fun with it,I am with mine.
Ummm... You try and keep the skis down yet you lowered limiter straps from 20 mm to 15mm? Sorry... I see a disconnect here.
just trying different things,playing around.Going to put my suspension back to stock this summer .I want to gain speed and eliminate comfort again.I want the SRX in total stock form the way it was meant to be..and fast..
