02 srx 700 secondary clutch question
Markbrown14
Alberta, Canada
Hey guys I bought a 02 srx a couple of months back and I noticed the other day that the secondary clutch moves in and out 1/4"on the drive shaft, i noticed it when i was changing the belt, almost seems like there's a bushing or something missing, is this movement normal?
its fine..should be about 1/8" on most Yamaha 2ndaries..I have 3 washers in mine..2-.5mm and 1-1.0mm.. totally normal that movement so clutch can center itself.The fiche calls for 2 washers..not sure their thickness off hand..
