phazer-exciter seat interchange
Kind of. Its not a big deal to put an exciter seat on a phazer II. You would have to make new holes for the rear studs though. Its a lot more involved to put a Phazer II seat on an Exciter because of the heat exchanger and hoses in the rear. It can be done. I have done it. I would probably not do it again.
sxr1000 said:
so the actual seat covers should interchange as long as I use the exciter base correct?
Yes as far as I know, or at least very close and doable. Are you puting a new cover on or are you thinking of tearing a cover off of an existing phazer seat??
I need a cover for a 92-93 exciter, I want an oem and they are nla, the 92 phazer le cover is still available and looks correct but has a differant part number just need to know if it will fit or what the differance is.
the rear below the tail light is a little different between the two, however I think little or no modifcation would be required. If I was in your shoes I would feel confident on your purchase. The mod, if any required would be minimal and any upolstry shop could do it.
