Mountain performance does not have any, and does not know if they will make any more. Does anyone else make these? I guess I could try and make one, but what a PITA. any help?
more than likely i have an extra one put up somewhere in a stack of plastic storage tubs, most likely with directions and slightly used, just need to dig it out if your interested.
did mpi drop those from their catalogue as well?
Backwoods M Max
I have the directions scanned as a pdf if you decide to undertake making them yourself. The biggest thing to find will be the laminated reinforced rubber. The straps in the kit appear to have 4 layers of some kind of hi tech fiber (aramid, kevlar) so they don't stretch. The only thing I can't give you is the hole spacing. But I could pull one out and measure it once the season is over.
