sxr 500 clutch set up ?
Shrader
Post Lake, Wisconsin, United States
I have been running vmax johns set up in the wifes sled for a couple seasons, seem doggy out of the hole until the rpms come up. It has a BPB primary spring as per his set up, wondering how much difference it would make if i install a WSW spring? should help engagement with a stiffer pre load, and raise shift rpm with the higher rate? just wondering if it is too much? it turns 7900-8000 now, but is supposed to be at 7800, maybe the wsw primary spring and loosen up the converter a little?
