snowprophet1
I picked up the max performance long travel shocks from a fellow member from this site but I can't remember who.  Shocks are in, springs and straps are set, but I need one dimension from somebody w/a tapemeasure who is using one of these kits...where the suspention bolts up in the very rear to the tunnel, to where the transfer rod bolts to the slide rail from center to center.  (total tranfer rod lenght, both pieces assembled, shaft center to bolt center.)  If I must make this length longer than the stock '01 srx length, any tips are welcome.  THANKS!!!!
			AtlasFBG2
The measurement your looking for is 1/4" longer than a stock transfer rod.On the 00-02 srx if you want full travel you either have to get Max perf rods for those years or fab a spacer to attach to the bottom of your transfer rod to make it longer.
			It looks like you have aftermarket rods installed (??Benders)  If so you can make them work with minor mods to the nut on the coupler end.  The measurement you are looking for would be best defined by getting the measurement of the oem rod, and compare.  I believe (memory) the limiter straps are to be set at 28mm, but not positive of control rod length...be sure to look into and double check, because it will have a major impact on ride---went down this road myself
