vmax 500 awful darting
hessracing
Iron Mountain Michigan
hey guys how can i get the machine to stop darting it has really nice 6" carbides on it and its riding on the front of the skis so heavy that it actually wore right through the ski skin in ront of the wear rod should i crank the springs in the front up or down or not touch them at all??
I would check out the rubbers in the mount (at ski) and check and see if the rear has a shim or not. If not put a shim (alot of guys use 1/4-3/8ish flat rubber cut square/rectangulr) in the rear of mont(between ski/mount) to level out ski pressure.
