oil light flickering??
kking32
moncton canada
never had this happen before, will riding the oil light sometimes starting flickering , most of the time real dim, then once in a while real bright, oil was full when left and checked it a few times to make sure it was using oil and it appeared to be going down. any ideas??
Is this a 2000? If no...Maybe a tank out of a 2000? 2000 had a bad batch of sensors. If this is your issue it should be brighter/faster flicker at low RPM. If 98-99 or 01-02 and you know its not a 2000 sensor than look for a rub threw.
