just a wandering,are the pistons from an SRX the same size pistons as in a 700 Redhead?
did some checking and part #'s are different,but wander if they still are the same diameter and such.If they were,I could use them with 700 cylinders and transform my 600 into that 700..but probably won't work.I have my old SRX pistons here and they look good still.
devinzz1
srx 700 has a 69mm bore and the red head has a 70.5mm bore
then can I put SRX cyl on my 600..lol....thanks for your knowledge there..
devinzz1
bluemonster1 said:then can I put SRX cyl on my 600..lol....thanks for your knowledge there..![]()
different size bores, same cc, means that the srx has a longer stroke. Not to mention that the way the ports are set up are to work with the powervalves and at that point I really dont know how things are gona go together.
