Those anyone know where you can get timing keys for the 01 srx 700?
This same question was asked a couple of weeks ago and I believe someone replied that Bender used to or perhaps still sells a timing key.You might try Hauck too.
hauck is where i got my last one.
YAMMIEGOD3:16
i got one. $20 3:16 (YAMMIE TONY)
YAMMIEGOD3:16
three. 3:16
Yamahakid01
How do they work on something like that?
I would be looking for something like 7 degrees
YAMMIEGOD3:16
Call Hauck. 3:16
Bullit01 said:I would be looking for something like 7 degrees
I have never seen a flywheel offset key that will give a 7 degree offset. I don't think there would be enough thickness in the key to allow it.
If you want to advance that much you may have to look at other options like installing a 2002 Viper CDI.
ssgzag15
Has any one tried to crank up the timing 7 degrees?
mopar1rules
tony i will take the timing key!!
3g racing
Viper CDi will give u 8 degreess would only run that in 500'
you start putting timing in a motor you better add fuel along with it, or youll be goin much, much slower with burned down pistons!
YAMMIEGOD3:16
i had a 3 degree key from hauck but damm if i can find it. i use cdi,s for timing for racing only. 3:16 (yammie tony)
