There have been a few threads over the course of the year where guys have complained about poor running engines or no spark and when a suggestion to replace the plug caps cures their problem I was wondering what the majority of them are using.Are guys buying OEM caps or are they using the NGK equivalent?
Before a bunch of replies start with what I should be using let me state I'm not having ANY spark issues I was just curious what guys are using.
staggs65
I have NGK's on every sled in the stable
Devilin AblueDress!
I to use the NGK. With me it has to do with cheap as dirt(less than $10 for 3), litterally can be found every where and they work!
I also am using NGK when I need to replace the OEM ones.
I went to stock OEM on my SRX..just because!!!
chris700readhead
I also run NGK.
ngk - found them on dennis kirk super cheap.
Anybody use MSD?
They aren't resistor caps, would that be an issue?
I've had awesome luck with them on PWCs.
Link ???suva57 said:Anybody use MSD ?
super1c
Super Moderator
NGK when I just replaced mine.
suva57 said:Anybody use MSD?
If they aren't resistor caps they likely are set up for just the threaded stud. Strange for MSD as they are mostly an automotive deal. Otherwise a cap is a cap. It just transefrs the juice from the wires to the plug.
I'd stick to resistor plugs though. Non-resistor plugs can be the source of some odd, almost unexplainable electrical gremlins.
http://www.msdignition.com/Products...ilicone_90°_Spark_Plug_Boots___Terminals.aspxLasse said:Link ???
Like these, Last time I bought a set for a V8 car for about $20. They are for the regular non-threaded plug top.
