SRX trouble code
shaggyzr2
Central Wisconsin
I have a 2000 srx, I just notice I have 3 flashes with the high beams on, when I put them on low I get one very dim flash, and 2 bright flashes, what could this be?
Sorry to say...ITS JUNK...I will give ya a couple bucks for it though......JUST KIDDING! The 3 flashes is the "good to go" code. My 2000 was doing some weird 1 flash for a while then back to 3 again. Probably something to do with the load control relay but I wouldnt worry about it to much myself.
Sooner or later it will develope another weird issue. The 2000's were more prone than the other years about the oil light "flickering", especially while at lower RPM. Bad sensor in the oil tank. You can change if ya want, mines ben flickering for the last 3 years, I fill before every ride on every ride so I know its not a low oil issue
