09nytroxtx
I am switching from a 144 to a 153 skid and track, cant get the back skid to tunnel bolts to line up. Do I need to move the mounting brackets or is there something I am missing, getting extremely frustrated, please help
Be sure to check the geometry of the donor sled. It very well may be different then the sled you are retrofitting into. I am not sure which skid you are using or which sled you are installing into. You might want to do a search on here, as there is a lot of good info on making skid swaps even if it is not about the skid you are using.
