gmcsrx
How should I start to load my HH's on a 02 srx ported with 155 hp with gwg spring, should be close for a piped viper also,thanks guy's;
I can not help you with the set up, but will tell you not to simply count on a viper set up based on hp. To many other variables---The tourque, suspension, gearing to name a few.
Sorry I cant help, but you may check the tech page.
Good luck!
Good luck!
Start with 1/2" allen in heel & 7/16" in 1st hole & 3/8" .8 gram in tip. Try that & it should be easy to fine tune from there. I can usually nail it in 2 changes.
gmcsrx
Turk I apreciateyour comments how tight do you run the secondaryfor top end speed,Thanks ;
Are you running studs? How much do you weigh? Is the helix stock?
gmcsrx
heavy hitter
Turk I have 144, 1175 studs and wiegh 195 lbs, stock gearing,and so far stock helix, we have just got some snow and start playing around,I ran 8bu-10 last year with good sucsess but suffered a little on top,I ran 47/43 last year at about 80 twist,today it seamed to work a lot better at 110 twist,some guys say the 02's like them tight is this what you have found,my set up today is 1/2 in heel 3/8 thick and thin washer in 1st and 7/16 and thin washer in toe and 8500 rpm's.Thanks;
