Having a hard time compressing red primary spring
Yamaha4life3
Rochester
Hey guys i have a heel clicker and i was told to put a red primary spring in it well i can not compresss it for thelife of me any tips or trick. Please
you should invest in a spring compressor tool.That is what I used when I ran HC's.I use the tool every time I have to open up the clutch to do work..makes it so simple,otherwise I was using my kness to push down on the cover..
Put a bigger nut and washer on your puller the push down and spin the puller in until tight. Then put in the 6 bolt for cover and tighten them all equal until tight. Then remove puller. All u need is a washer and big bolt.
