Viper steering arms on SRX?
fourbarrel
VIP Lifetime Member
I was sitting here perusing eBay and this thought run through my head,will the aluminum steering arms from a Viper fit or work on an SRX? Over the years I've seen the aftermarket aluminum ones made for the V Max/SRX on places like eBay but nobody makes them any more and finding a set now is like finding hens teeth.I was just wondering about replacing the steel ones with aluminum is all.
they will if you use the long tube arms.
or you can use viper top cranks with apex spindles
viper spindles will also work in rx1 steering knuckles as rx1 spindles will work with long tube trailing arms.
all above is not without grinding a little knotch here or running wihtout snaprings.
Yeah that's a bit more screwing around than I figured on doing,if they would have slid on there without having to change stuff I'd have thought pretty strongly about getting a set but I guess I'll just keep looking for a proper set of aluminum ones for the SRX.
