I am looking at an '01 SRX and the seller says it has a new track. I know it is not the same as my other SRX which had the original track. He says this one is a 1.25". Does anyone know what brand it is and if it is good. Also with a 1'25" track, if you were going to add studs woth they have to be at least as long as the 1.25"?
Also he says that the hood has "spider cracks". If you look closely in the pic you can see them, does anyone know what causes this?
track is a 1.25 camoplast ripsaw. the cracks are caused by some type of impact. they form when the hood is deformed (bent) enough to crack the gell coat, but not enough to crack through the hood.
Is that a good track for these sleds?
YAMMIEGOD3:16
do not stud it. but great track. 3:16 (yammie tony)
Yamahakid01
*2 on all of it possibly a roll over or a clutch/belt explosion
For less than a grand I can't go wrong
Devilin AblueDress!
If you roll the track around it should say right on it. CAMOPLAST and the make/model number. X2 on flex far enough to crack paint but not the hood itself. Is it just on the left side or all over the hood? Could have ben a too many barely pops and some one tried leaning on it while was open.
