Whats the spacers for 00 SRX
new specs for settings
The updated specs for the control rods for the 2000-02 srx are 2.5mm spacers on top and bottom, this reduces hyfax wear, better transfer, limiter strap length at 42mm. Right from the tech 02 update suspension book. The previous settings were 15.0/5.0mm, 32mm strap length.
So the top spacer gives you transfer and the bottom controls ride quality.Correct?
If I want less transfer than I would put in a 15mm spacer up top?
If you want less transfer put bigger spacer up top,the more you limit the travel up top the less transfer you will get.I would pull the limiter straps up myself if you want less transfer,this will help with hyfax wear as well.-Harvey
I really dont know what the bottom one would do other than limit the amount the suspension can drop when uncoupling.-Harvey
