MonctonR1
Wanted to get some red or yellow loops for my new plastic skis but after pricing them out.. OUCH!
Anyways... Is there anyone out there that has painted them with some sort of spray paint!
Thiking of just painting it black?
cleansocks
Kryon fusion paint for plastic. I bought some with the instensions of doing my loops too, but haven't gotten around to it yet. It worked great on my pull start handle though.
MonctonR1
And it stayed on! Sweet! That was just the confirmation I was looking for...
TopGunnSrx
Dont paint them! My neighbor did his ski loops white with that krylon crap lasted a whole 2 minutes dont do it just buy them!
I've seen it done and it looks tacky. The paint chips off then you are left with ugliness. You should be able to find a set of loops for under $30.
Don't do it!!!!!!!!!!!!!!! I did and it was a mistake. I even used the Krylon Fusion.
seanmurphy26
i used the stuff on my windsheild haha im cheap like that but it looks good. anyways dont try using it on a ski loop lot of vibration there most likly it will just chip off. stillw aiting for a stick to hit my winsheild and have the paint just fall off.
TopGunnSrx
Did you paint the inside?seanmurphy26 said:i used the stuff on my windsheild haha im cheap like that but it looks good. anyways dont try using it on a ski loop lot of vibration there most likly it will just chip off. stillw aiting for a stick to hit my winsheild and have the paint just fall off.
ridesrx
he should have
if you use a good soft enamel spray bomb or better yet a vinal color. I had done a set on my srx. you will need to sand them with a grey scotch brite and clean them with whip or other precleaner before painting. the ones i did lasted all season with only minor chipping on the tips and at major flex points. each year i just removed and sprayed again.
MonctonR1
Looks good to me!
