Frantz600st
Is there a big nor kit for a vmax? Or even oversized pistons that will allow me to make it like a 620 or bigger? Could anybody tell me what size the tie rod ends are
			mbarryracing
- Aug 30, 2007
- Springville, NY
- www.fullpowerperformance.com
Historically big bores for the 600 twins made no more power then stock, from any company, proven by the fact they still only pulled stock clutching. Waste of $$$, better spent on getting a set of 97 triple port cylinders, get good extensive porting and combustion chamber recut by a reputable builder and your 600 will make more HP, realistic 140HP on pump gas.
			Hammer Down
Vmax4 Pro Stock 800 dirtdigger = badass
			Frantz600st
I was just wondering because my cylinders are badly grooved and its way cheaper to bore them than exchange
			hauck used to do a 700 kit for the 600 twins, may be worth a call.
as for your heim joints(tie rod ends), pretty much universal from most yamaha sleds. keep in mind they are handed per side thread wise. i have a few in storage.
Frantz600st
Found it and emailed them about it. How good and reliable is it? What about clutching and jetting? I have a Polaris clutch on it and power reeds with twin psi
			INLINE4
- Jan 6, 2006
the whole thing is being a self tuner..There's alot
