WedigSRX
Pulled the motor to fix a leaky water pump.
11,500 miles on it.
When do you guys suggest replacing crank seals ?
No problems but thought I might replace them since the motor is out.....
11,500 miles on it.
99srxracer
I would do it now. Almost 12k motor is out seals are cheap easier now than later and sumthing you know you wont have to worry about
I would suggest once you have to open up the motor,might as well do a top end rebuild as well.
