kallio
on the 1980 exciter I picked up the piece of plastic that holds the part of the gas cap that moves broke. I tried to JB weld it but it didn't hold - has anyone else used something else that worked?
Cooper0809
I would look at just buying a new one from royal distributing. theyre probably $10-$20 bucks for a new one.
Are you looking for the little metal flipper?
kallio
it's the piece that is apart of the actual tank that the cap attaches too
kallio said:it's the piece that is apart of the actual tank that the cap attaches too
Can you add a pic?
kallio
ill get try and get a pick up tomorrow
opsled
The tank is polypropylene. No glues will stick to it. Welding is the only fix for them. Wasn't a common problem with that sled and 78-81 Exciters all used the same tank so I'd just find another.
Should not be hard to find.
opsled
opsled
