True2blue
Looking for any info on a hard to start 02 srx 700, cleaned carbs, new plugs set up enrichers and still pull my guts out when the engine is cold. Replaced stator so I'm sure it's not electrical, just doesn't want to pick up the fuel, and fuel pump seems to be working fine. Open to suggestions thanks
FJViper
Move this to the SRX/Viper forum. You'll have better luck there.
Done!FJViper said:Move this to the SRX/Viper forum. You'll have better luck there.
shaggyzr2
When was the last time the fuel filter in the tank was replaced?
Start with the basics. You need 3 things to start, fuel, spark and compression.
The engine hasn't been apart lately so we will rule out lack of compression.
Start by seeing if you are getiing spark at the cylinder. If you are, you are left with a fuel issue.
YAMMIEGOD3:16
WHEN YOUR HAVEING PROBLEMS, PULLING LIKE CRAZY, STOP AND PULL SPARK PLUG OUT AND MAKE SURE ITS NOT WET. OR GETTING WET. 3:16 (yammie tony)
