1.) rusty flywheel is the most common from storing them, you can see it right by the recoil. sand it and clean it off with brake clean, give it a coat of light oil when done reinstall recoil.
if no spark, then check the :
The pickup coil failed in my srx 700 last year while being stored in the offseason, if you can get a shop manual or the download you can test with an ohm meter
