carb question
JSTYER
WI
I got the carbs off my SRX for cleaning, which carb is #1 and #3? I got the one on the mag side tore apart and see it has a 147.5 main jet, is that right on a 2002 SRX? Mag side is the is the side with pull start cord correct?
easy way I remember is 1 is clutch side and 3 is pipe side and yes 3 is the mag side. remember there's always the tech page
I haven't tore into the other 2 yet but it seems that the 147.5 that is on the carb tore down should be on the clutch side correct? I can tell they have been apart before so just wondering if someone put the jets in the wrong carbs. I will tear into other 2 tomorrow to see what they have
Well I tore into the other 2 carbs and as I thought, there was a 146.3 on the clutch side, in fact! When I took the bowl off the main jet fell right out, it was never screwed in! Could this be the problem I had with the bog and not getting over 7500 rpm? Also the pilot jet orfice on the center carb seems plugged, can't get an even spry of cleaner to of through like the other 2, how do I clean that? Thanks!
