Hammer Down
Who is running it? Will it be a problem on a 750?
If your going to do any modz on the 750 you have to weld your crank
Hammer Down
Can the stock 800 handle it?
YAMMIEGOD3:16
750 WILL TAKE CRANK WORK. 800 SHOULD BE GOOD IF ITS A MILD SHOT. 3:16 (yammie tony)
YAMMIEGOD3:16 said:750 WILL TAKE CRANK WORK. 800 SHOULD BE GOOD IF ITS A MILD SHOT. 3:16 (yammie tony)
Would you consider the 40 hp kit a mild shot?
jabber800
I would!
YAMMIEGOD3:16
very mild. 3:16 (yammie tony)
Hammer Down
Where can these kits be purchased. 40 hp at the push of a button sounds like fun. Are they wet or dry systems?
HP + sled = BIG $$$$$$$$$$$$$$
Hammer Down
Turch's equation is true ....found One for about $1000 bucks. Yikes. Bought a 125hp kit for my car once used for$150.
There used to be, I think 2 companies, that made systems specifically for the Vmax4. I don't recall the names. Anyway, I would suggest trying NOS first. They are pretty much the top of the game for nitrous systems, and may in fact be one of the companies that had a kit.
Straightline Performance can design a kit for the Vmax 4.
spirudamax750
I will be welding the crank on my 750 next year where is a good place to send it or would it be easier just to get an 800 motor
YAMMIEGOD3:16
never easy to get a 800 motor. there out there but not on every corner. 3:16 (yammie tony)
Hammer Down
How long does a 3lb nitrous bottle last? How many seconds.
YAMMIEGOD3:16
you will need fill up station. 3:16
