J bic
Greeting,
Can anyone tell me how to visually tell the difference between the 750 and 800 exhaust?
The reason I ask is I am looking to put the 800 exhaust on my 750 for the hp gain. I just want to make sure I'm getting what I paid for.
I apologize if this has been discussed, but I couldn't find a thread on it.
Thanks in advance!
Thanks in advance!
YAMMIEGOD3:16
YOU PUT THIS IN WRONG FORUM. DIFFERENCE IS IN THE '' Y'' PIPE. I HAVE SPEC IF YOU CAN MEASURE ONE YOUR LOOKING AT. THIS EXHAUST WILL ADD HP TO THE 750, BUT CHANGE JETTING ALSO TO 800 SPEC . 3:16 (yammie tony)
Relocated to correct forum.
J bic
Thanks Tony, I can measure it. What should I be looking for. Again, thanks for the help.
Can't wait to try this sled out!
J bic
Sorry Mr. sled, still trying to navigate.
YAMMIEGOD3:16
YOU NEED TO MEASURE THE INSIDE DIAMETER OF THE '' Y'' PIPE. ANOTHER WORDS THE END WHERE THE PIPE FITS IN. ALSO, ON THE 800 THE Y-PIPE END IS A MACHINED FLANGE, WHERE THE 750 HAS A FLARED END.
750 - 46.2 mm INSIDE DIAMETER
800 - 48 mm INSIDE DIAMETER
ALSO POSSIBLY YOU MAY FIND A 8BU STAMP ON PIPES. 3:16 (yammie tony)
J bic
No stamp but it measures out. Thanks for the lesson!
YAMMIEGOD3:16
J bic said:No stamp but it measures out. Thanks for the lesson!
3:16 (yammie tony)Canuck
The inlet pipe on the expansion chambers is also 2mm larger than the 750.
