MM70001
What pistons are best for a piped 700 Readhead OEM or Wiseco?
YAMMIEGOD3:16
I LOVE OEM, NEVER RAN ANYTHING BUT. I HAVE SEEN WIESCO WORK IN THIS MOTOR. WITH THAT SAID, I WOULD GO OEM FIRST. 3:16 (yammie tony)
staggs65
if you go wiseco you absolutely must let the engine warm up fully every time before you touch the fun flipper or you will cold seize sooner or later.
Cwagner100
How does those spi coated pistons work??
I love all piston which is available in the market but i mostly like OEM piston in my motor same this piston i used its work very well no problem with it...
chris700readhead
OEM with swaintech coating best setup IMO. And you don't have to wait after you stop to get gas.
