99srxracer
First is im running 01 srx with cold air intake. airbox mod. Clutching but not sure what reeds and a bender can. I like the sound but is it worth putting stock can back gaining the wieght for the hp?
Next is just fired sled and coolant light flashes 3 times pauses and does it repeatedly. Im thinkin wire rub thru? Coolant clean never overheated. Anyhelp be appreciated
staggs65
I'll have to look to be sure but off the top of my head I'm thinkin that's a powervalve code. I'll check for sure and post back. as far as the can, yes they lose a little power but it depends on what you want out of it. Some guys are happy with a slight loss of top-end power and the extra sound, some guys would rather be quiet and fast, riders choice. either way the average trail-rider probably wouldn't notice the difference, it would come down to the sound they prefer. When you're searching for every available pony racing is when it would matter.
staggs65
I was wrong on your code, per the tech pages 3 longs is your thumb warmer. Is that working?
99srxracer
Thanks staggs ur prob right i unplugged em putting bar riser on. I check it out
YAMMIEGOD3:16
NATE, CAN IS A GREAT WEIGHT SAVOR, AND MOST SOUND LIKE TURBO, BUT STOCK CAN WAY FASTER. JEFF IS RIGHT ON HAND WARMER CODE. 3:16 (yammie tony)
99srxracer
Thanks guys i changed my dash peice from black to blue must have plugged it in wrong maybe. I dig into it tonight. I have both cans idk wat im gonna do yet
99srxracer
Yup tony and jeff hand warmers now workin and lights gone thank you
YAMMIEGOD3:16
99srxracer said:Yup tony and jeff hand warmers now workin and lights gone thank you
