Stiff Steering
mkalbarc
It's been awhile since I used my sled and I noticed that the steering was very stiff. I sprayed something called super lube on all the joints I could see and the steering got a bit better, however, it now squeeks very loud when turning either way. What's a good lube to use? Thanks!
what sled is it. Yamaha has grease fitting for the steering that should be greased every year. Ther maybe hardened grease in these.
Under the pipe, I have cpr triples and can see mine, but with stock exhaust I don't no. Just look under the pipe and you will find it.
