Mtnviper
When switching from the gray spring (230-330)to the red one (230-360). Approx how much tip weight would need to be added, to keep the upper end rpms close to the gray spring set up?
Brad
- May 23, 2003
spring
I think that the choice in spring only dictates ingagement rpm
Mtnviper
Preload is the same for both springs. The engagement chart that comes with the kit, shows engagement rpms the same for both spings. I havn't tried the red spring yet, ( had to order it) so I'm not sure if this would be the case on my sled.
sol-sask
- Sep 8, 2003
actually your engagement will stay the same but your rps will be higher with the red spring......put at least 1 to 2 more washers in the tip to stay close to your high rpms setting.....
Mtnviper
Thanks, so approx 1-2 grams then. I'd like to try and get it close so when I'm out riding/testing I can do more riding than wrenching
edsdrag
- Oct 26, 2004
would you be intrested in selling your gray spring if so how much?
