Hi
After playing back and forth with clutching, I managed to loose my 15 mm rollers that I use as a part of my set up for the 01 mm 700 stock.
I have to buy new ones, but I cannot figure the right part # for these.
I looked at the rivets and rollers chart in the tech pages, and it lists up 8mm ID rollers as 8ab-17624-00-00. However, if I look at hlsm.com, the 15 mm (8mm id I suppose) are listed as 8cr-17624-10-00
which is the right part #?
thanks
thanks
Looks like the the 97-> 2 strokes use 8cr. Is this right?
correct. 97 and up went to the 9mm pins on most sleds. your sled uses the 8CR pre-fix for rollers.
