snoprokidf6
anyone know where i can buy bulk fuel lines the same diameter as the stock yamaha ones. i bought some stuff from advanced auto but its a bit big, it will work but none of the clamps fit on them.
ILVmax4
When I need fuel lines for my Vmax-4's I have ordered part #91A20-05145-00 from the Yamaha dealer. That is the long fuel level hose for an Exciter II. I cut this in to the size I need. Online list price is $8.72 for about 4 feet. This is the fuel line that has a pink tint.
Thanks Opsled for the above tip!
YAMMIEGOD3:16
DON,T SCREW AROUND, GO TO YAMMIE DEALER. 3:16 (yammie tony)
blue800
Yamaha lines are a lot cheaper than watching your sled go up in flames
from leaking fuel
from leaking fuel
mrviper700
VIP Lifetime Member
yamaha line is metric,so thats why 1/4" std line is loose fitting,and yes they will seep/leak some. You can use zip ties to tighten them up some as you found out the factory clamps wont work on it. All in all, I just use the yamaha fuel line, its not that expensive and fits correctly.
