Just wondering if the secondary buttons from shade tree are any good. They are selling them alot cheaper then you can get them from any wheres else. Normally you get what you pay for. Have anyone used these before and are they any good? Thanks for the input.
IDK other wlll say other wise. I run them a yr and change them out needed or not. Not shade tree ones but do run cheap ones from automatic distributors.
I think I read a guy on here who had a bad experience with an aftermarket rebuild kit. I would just buy OEM, they will last for years anyway.
super1c
Super Moderator
Not sure about shade tree ones but some aftermarket ones i got were junk. They didnt even fit tight in the holes? I know the oem ones are expensive but they are way better. I think i paid like $10 a piece. keep your eye on ebay, have found OEM ones cheap. Chris
thanks for the info. I have had good luck with OEM. I will probably stick to them. Cost more but get better parts. And I know i would not want any loose fitting parts. Thanks guys
not getting work done today being on here lmaoRB2001SRX700 said:thanks for the info. I have had good luck with OEM. I will probably stick to them. Cost more but get better parts. And I know i would not want any loose fitting parts. Thanks guys
work can wait this is more important....lol
SWEDE
I've ran the Spi brand ones for years, there like a buck a piece. They do wear faster, but at 3 bucks vs. 40-45 bucks for replacement you can afford to change them every couple years. Slightly loose fitting is not an issue in use. Both of the dealers north and south of me carry the Spi ones seeing there so much cheaper......
