huack big bore 800 questions..
roscoman
mich
wonderin if anyone out there has any experience with the huack big bore 800 motor.. im picking one up this week..it has around 175 psi on all 3 jugs!! i believe with that i need to stick to race fuel..i know im gonna have to get the crank 100% welded but is there anything else i shold do b4 reassembly? any ideas for clutching and carb setup? this sled is just gonna b riden 2-3 times a year at local drag races on ice/hayfields..any guidance would be great!!!
thanx for ur time
If it has 175 psi, you will probably not want to run that on gas pump fuel.
What year is it? If it's 2000 or newer, the crank might be just ok, check anyway. Besides, I think the engine builder would weld it, since he probably had it out anyway.
Can we get some pics please?
To be able to give some clutching tips, peak rpm and hp would be apprechiated.
thanx for reply.. im picking up the sled later this week and will be sure to give more info as i find out myself!!! im pretty pumped up about this.. ive wanted to have a drag sled since i was 15...thanx 4 the help!
