air forced brake rotor cooler
Ames2000
Sabattus
on my srx put the connectors for a cool down cart in. The plastic brake rotor cooler thing dosn't fit with that connector there. Do i have to run that in there or will i be all set for grass drags with out it? Thanks
Id say you should be fine also. If you were hammering tight twistie trails, then I'd say you'd want to keep it in place. But for drags, the rotor will have plenty of time to cool down between passes
