yammieguy
Not my sled haven't had a chance to look at it yet but guy says all 3 cylinders are toast.. oil related?
need pics to determine that. most likely culprit though.
roudyroy1
wow! all three?! yeah i would guess that's oil. usually with lack of oil the bottom end goes first in my experience.
auji700triple
Rare to see a burn down on all 3 at once, that's terrible. Oil injection failed?
yammieguy
I will have to get a look at it myself and report back. He says all 3 are right down on compression, I would think even if oil was the culprit one would lock up first? If the oil pump failed isn't it likely to be stuck open?
I have seen all three with a broke oil pump failure and the pistons get dry and fall apart.
auji700triple
I have had the oil pump fail on my piped viper. I lost the mag side piston only, I pulled the pump and found it wasn't pumping any oil at all... Not fun being deep in the woods and loosing pistons...
supervr4230
I would try another compression gauge!
Suprx125
supervr4230 said:I would try another compression gauge!
x2. What are the compression readings he getting?
