Hammer Down
I looked at a 600 that has a 700 motor installed. Are there any other differences between the 600-700 srx besides the motor. Wondering if 600 driveline can handle 700 power.
I think you'll find that the chassis is the same the only differences will be the clutching components ( weights,rollers,springs,helix) and gearing.The engines actually share the same bottom end it's the pistons,cylinders and heads that are different.
My 600 worked quite well with 780 stuff in it so I don't think it would be a problem with 700 stuff.
YAMMIEGOD3:16
same sled. 3:16 (YAMMIE TONY)
