spirudamax750
Got 800 pipes and got new set of carve for it cant waitto get it on her
YAMMIEGOD3:16
change jets. 3:16 (yammie tony)
Ryan-- Here's a good place to order jets from:
http://stores.ebay.com/Niche-Cycle-Supply?_trksid=p2047675.l256
spirudamax750
Would I be fine with 145 main jets
YAMMIEGOD3:16
you have to go to complete 800 jetting. the stock 800 twins do add power. that means complete change. mains, pilots, needles. 143.8. is stock, but get what you can find. 3:16 (yammie tony)
Rustman
I have run 140 mains in my 93 with 800 pipes for 3 years now with no issues. I also went to a 50 pilot. Used stock 750 carbs. The stock jetting in a 92 was 140's and 50's, unless they have been changed out. 93's went to 135's and 47.5's.
spirudamax750
I cant read what my stock 92s are
spirudamax750
Ok ill do 145 and what do I do with the needles Tony
YAMMIEGOD3:16
ryan i would not chance it running your 750 carbs with a 140 main and just up pilots. my worrie would be in needle jet. the 800 pipes on the 750 is not a myth, there will be a change. i thought you told me you had 800 carbs. 3:16 (yammie tony)
Rustman
145's will be be nice and safe and fat I would think. I have run mine wide open for miles and had no problems. Never touched the needles.
spirudamax750
No 750 carbs
spirudamax750
I want to make it as best performance I can so Tony whatever i have to do just let me know
spirudamax750
Tony ill talk to you 2marow about it I found out some info need to see if you agree with it or not
YAMMIEGOD3:16
if ya can,t get to exact 800 spec, sure up mains, up pilots, and i would change needle position. 3:16 (yammie tony)
